Oil Pan Gasket
Old Sep 2, 2011 | 06:12 PM
85300td's Avatar
Default Oil Pan Gasket
New oil Pan Gasket installation,with silicone or gasket alone?
Old Sep 2, 2011 | 06:26 PM
85300td's Avatar
So NO? another thing on my next oil change I might also consider looking at check valve on the oil separator drain tube ( it's kind of leaking atop sump as typical ), could this piece be simply removed /cleaned and reset or should it just be replaced?
Old Sep 2, 2011 | 07:10 PM
85300td's Avatar
I'm just gonna order everything at once, better safe than sorry.
Oil pan gasket, tube O rings [top n bottom], and check valve .
Missing anything while pan is out?
Old Sep 2, 2011 | 08:49 PM
85300td's Avatar
Originally Posted by ForcedInduction
Oil pump pick up tube. Its always brittle from age/heat and very likely split or deformed.
Got a part number or something I can plug into a website?
Seems like if the pickup tube and oil pump were a one piece item?
thanks,
Old Sep 3, 2011 | 10:51 AM
benzguy's Avatar
Have a good look at this......
benzguy
Cheers
Big Dan
Old Sep 3, 2011 | 12:31 PM
85300td's Avatar
benzguy
Cheers
Big Dan
Nice write up, except my turbo oil return is not leaking and does not look anything to what yours did. My issue is the oil separator oil return pipe ( that is looking like crap). Are the O rings the same for the oil sep. return as for the turbo return?
vegasgirl500sl
Dec 17, 2006 02:21 AM
quickwrench
Dec 9, 2006 05:22 PM
wilbur1
Jul 25, 2006 08:34 PM
wilbur1
Jul 24, 2006 12:32 AM
bbull55
Aug 25, 2005 09:44 AM
