OIL CHANGE!!!WHICH OIL & FILTER TO USE???
I have 2 MBZ TD 82 & 87. I want to change the oil what should I use 15/40 or higher??? Is the diesel filter different then the regular??? I 'm asking for help...Please help. Thanks in advance
Spicy, Good Question:
Make sure you use a Mahle filter as they are an OEM supplier for MErcedes. They are very good filters.Use 15-40 engine oil. Rotella is one ofthe best.
If you want more information, the best website I know if is dieselgiant, Actually, they have a tutorial on a diesel mercedes oil change at the following link: http://www.dieselgiant.com/mercedesdieseloilchange.htm
Cheers,
Tom
Cheers,
Tom
