Nozzle shims
Old Feb 19, 2026 | 03:51 PM
noswendel's Avatar
Default Nozzle shims
i VEIWED AN INSTRUCTIONAL POST ABOUT REPLACING THE INJECTER NOZZLES ON MY 81 240D. IT SAID YOU COULD REUSE THE SHIM IN TTHE OLD NOZZLE AS LONG AS YOU DON'T MIX THEM NOZZLE TO NOZZLE. i SAW ANOTHER INSTRUCTIONAL THAT SAID YOU HAVE TO TEST THEM (I've ORDERED A PRESSURE TESTER) AND PROBABLY PUT IN A NEW SHIM BASED ON THE INJECTER TEST.. OBVIOUSLY THE FIRST WAY IS EASIER SO I'D RATHER DO THAT IF IT'S THE CORRECT WAY. IF I NEED TO CHANGE THE SHIMS,WHERE CAN i GET THE SHIMS THAT GO INTO INJECTER NOZZLES ?. thanks FOR YOUR ASSISANCE.
David6FL
Aug 24, 2013 09:21 AM
und396k
Sep 9, 2009 09:16 PM
RubrDckie
Jan 28, 2009 11:17 PM
Mr.47
Nov 21, 2006 11:03 AM
edfer
Feb 9, 2006 02:42 AM
