newbe with an 85 300sd
Got it last night things a tank I love it. Have some issues n hope I can get some help.
Issues: speedo,tach,odo,Crouse control all dont work. The oil seems low but don't know since there's no markings on the dip stick n I don't know how to read it. Also Tranny shifts hard, n seems like I have to floor it for it to move! Also for upgrades im gonna change the radio tint the windows take off the muffler n make a cai but inclosed utilizing some oem parts just need to know where to reroute the oil breather tube on top of the stock airfilter canister? Please help will post pics soon! |
Anybody?
Awesome thanks for the reply!
So I went to get a new air filter n the only one they have is 68$! Its a taller skinnier one then the one they keep comming up with. Also checked for broken vaccum lines n they all look good. Replaced 90% of the fuses but havent had a chance to try the cruse control. But half the cluster tack speedo n odo still dont work. |
Looked up n foundnout my car is an ca mb with the "trap oxidizers" anyway to get rid of the "ca trap oxidizers" system n idea of cost?
Originally Posted by ForcedInduction
(Post 161506)
Ah, you have the football-sized tumor under your turbo with the air filter by the headlight?
From a federal model 300SD you will need; Air filter assembly Oil supply and return tubes Intake and exhaust manifolds Exhaust down pipe Turbo compressor cover without recirculation valve, or the whole turbo You can reuse your turbo if you change the compressor cover and rotate the turbine housing. Its cheapest if you get your parts from a pick-n-pull yard. Thank you for the help and the replys by the way. Would it be any benefit of of getting the intake and exhaust manifolds n upgrading the turbo for a power increase with everything els stock? |
Bummer. I would like to make a few more poneys. was thinking air-air intercooler, manual boost controller?, straight pipe (love the sound of turbos), adjust the IP as needed. On a budget of $1k for upgrades n needed parts.
