Mercedes 300 SD - Any hints on removing the head on a diesel engine
I am trying to remove the head off a diesel engine. I got them all off except the center row. They are a size 12mm allen.
I can't get them off and afraid I am going to strip the bolt head. (I have a 3 foot pipe on 1/2' drive breaker bar).
Someone said try heating the bolt. Any other suggestions?
RE: Mercedes 300 SD - Any hints on removing the head on a diesel engine
Thanks for the post. I looked up the "triplesquare". I already removed all of those bolts (with a star type socket).
Then I removed the cam shaft. Under the cam shaft is a row of apr. 5 bolts. A 12 mm allen just about fits right. (just a hair loose). Note: the top of these bolt heads are just about flush with the head so there is no way, in the event of striping the allen socket, that I can cut these bolt heads.
I put a 3' pipe over the 1/2"breaker bar to help get some turning leverage and with all my might, I tried unscrewing the bolt. No luck.
(PS: To help push down on the socket, I ended up straping a wide tie down strap around the engine and over the breaker bar and pulled the socket super tight into the bolt.) I have tried turning but now the allen is turning in the bolt headand is coming close now to striping.
Any other hints?
Scott
Any other hints?
Scott
As per FI 's instructions : "It is not an Allen"
"Almost Fits" or "It's a tad Loose" will create a nightmare scenario which you are enjoying now!
Proper tools use on Mercedes is almost paramount to a successful repair.
To answer your question: You are ****** on this repair...pray and hope that a machinist
can drill and remove the offended bolt (If you cannot with an "Easy-Out")
Chances are you've "boogered" the other bolts also with this treatment...No worry,replace with
new bolts WITH the proper tool.
Popes
07-06-2015 04:31 AM
Mr.PotatoHead
03-30-2008 01:20 PM
xjvoorheesx
07-29-2006 02:21 PM
