Master Cylinder? No Brakes
Master cylinder is leaking in the noisy yellow Benz. : P
This could case loss power in the brokes correct? mabey air in the lines
Going to the mother of all junk yards tomorrow, see what i can find.
Thanks for the Help!
514,000 miles and counting.
A brand new master cylinder for your car is $80. from Autohaus AZ.
http://www.autohausaz.com/search/pro...ter%20Cylinder
Don't take chances with a used one when a new one is so inexpensive. Also, they only take half an hour to change (if you don't count the time you have to spend bleeding the brakes afterward).
Thanks for the help,
I think mines fine, just need to get a new gasket for it, i got once yesterday going to go put it soon....
If it doesnt cure the problem, then i will be buying a new one. : )
