Injector Pump
Old Nov 1, 2010 | 11:14 PM
  #11
paddo's Avatar
I tested the pump from out of a can today, and got the same result so that eliminates "upstream" problems. Also I can squirt fuel out of the by-pass hose (that clamps to the top of the spin-on filter from the engine side of the fuel distributor/inj pump) with the primer pump, so that suggests the by-pass is working OK too. The surprising thing is that it seems to be running on diesel by the injection pumps alone (I assume there's one for each cylinder), although not too well.
Now that I have a better idea of the lift pump I'm leaning more towards thinking it might just be a failed, probably clogged valve. I don't know how the actual pump piston is sealed but it was a sudden failure so doesn't seem like a failed pump mechanism unless there's a piston seal that can suddenly fail. Anyway I'll aim to take it off tomorrow.
I can't find the valve kit on peach parts, they just seem to have the whole lift pump for about $250. Should get a gasket from a dealer I suppose but it's far away. I could just get gasket paper and cut it out.
Old Nov 2, 2010 | 08:43 PM
  #12
Diesel9112's Avatar
The Piston inside of the Pump has no Seals. It is just a close tolerance "slip fit" metal to metal.
I have seen the Spring Break on them and I have also seen where grit or rust causes the Piston to stick and not move.
However it is more likely that there is something gunking up the 2 valves or under the Valve seating area. The springs on the Valves are not very strong so they cannot seal if anything thick or gummy gets under the Valve seats.
The Pic on the left shows the Pupm Piston and Spring. The Pic on the Right shows the Roller and Tappet, Rod and the little O-ring that goes in a groove inside of the pump Housing. I do not have a pic showing where the Valves go.
Attached Thumbnails Injector Pump-lift-pump-piston-spring-plug.jpg   Injector Pump-lift-pump-1.jpg
Old Nov 4, 2010 | 12:35 AM
  #13
paddo's Avatar
I got one from a wrecking yard yesterday ($20), put it in today, and nothing! CAn't even get the hand pump to work anymore. Looks like good old Mr Murph ******* me again. I mean you can't expect good parts from a yard all the time, but this seems like a very rare failure. Anyway I had a look at the old pump, it seems there's no spring pressure on the pump piston at all it's just loose, so must be a broken spring I assume - unless the spring is not very strong and can be gunked up in compressed position. Got one of the valves out and the spring was gunked up so I freed that up, couldn't get the other fitting off yet it's as tight as something rude. Anyway I'll take the "new" pump off again tomorrow if I have time, I don't recall that the piston was loose so probably it has valves that need a clean-up. If necessary I can use ones from the old pump.
As far as the O-ring goes, I wonder if I should try to replace while I'm at it. Hopefully this is a rare failure even for the whole life of the car, although you'd think it would probably fail after 30-odd years. I might just leave it for now, especially since it's another problem finding a new O-ring. I could replace it with one that looks right and actually cause a problem, so I may just wait until it fails although that might be hard to detect until it gets pretty bad.
HOpefully both valves are a bit easier to open up on the replacement pump.
________
Cb1300
Old Nov 5, 2010 | 12:50 AM
  #14
Diesel9112's Avatar
I have seen Pumps where th Piston compressed the Spring and stuck like that. You will not know until you remove the 30mm Hex Plug.
If the thing Copper Crush washer on the 30mm Hex Plug remains in the Housing do not try to pry it out as it will get too buggered up to reuse if you do.
However, since you discovered that one of the Valves was gunked up what does that tell you about your Fuel?
Old Nov 5, 2010 | 02:00 AM
  #15
paddo's Avatar
I got the other 19mm fitting off today, with aid of a new socket set from Pepboys, and a slightly skinned knuckle when it finally gave. They didn't have a 30mm socket, they had a bigger one I think 33 or 35mm, and 1 1/4 and 1 1/8th sockets. I think it would be in between so not sure if either the metric or the imperial sockets would be a good enough fit.
I'll have to take the other pump off anyway so can probably avoid removing either of the 30mm's. I lightly sanded the plastic valve faces with some 800 grit sandpaper (on a very flat surface of course) to get the scoring off, and found they seal much better now - you can test them just by blowing and sucking on the fittings. Not quite perfect but I suspect they don't have to be. I also pressure tested the O-ring and it is totally sealed. The ring only creates a light drag on the push rod, but obviously it is enough.
If I can't get either one to work I have the option of putting an electric pump inline just before the input, which would be an interesting experiment and you can get them for about $30.
RE fuel it's been a learning process with the filtered waste veg oil. For one summer I wasn't even flushing before switching off since it was running fine and even starting on the veg. But started having blockage problems then, probably from the oil sitting cold in there and some waxy type of stuff precipitates out. Something was really jamming closed for some starts, probably a valve. I've since been more careful with flushing, and also nearly always use oil from a seafood place which is a lot cleaner, so current gunk is likely left over from back then but I'll up the flushing a bit.
But there's definitely a price to be paid for using WVO but it sure isn't at the gas pump, so it's well worth it so far, and quite a good hobby as long as you don't mind getting your hands dirty and can do your own tinkering with the system. A bit riskier on a more valuable vehicle since there's the chance of it shorting the life of the engine. In that case I think I would be more stringent with the bag filtering (ie 0.5 micron if possible), flushing and preheating system. My merc is so rusted underneath that it is practically ready to fold in half under there.
________
Honda Wave series specifications
Old Nov 6, 2010 | 06:40 PM
  #16
paddo's Avatar
Got the yard pump off today, nothing wrong with it. BAck on and it's running fine at last and back on free fuel.
I blew and sucked on the inlet and outlet lines and the valves are working perfectly, took out the input valve and it's very clean, virtually no scoring. I think one of the valves must have been stuck open from sitting for a long time and until I sucked on it there was no good reason for it to free up. probably could have just sucked on the input line without taking off the pump, or could have pushed fuel through it somehow - once full of fuel the pump would have probably freed up the valves - put it down to experience to check the valve function before installing. O-ring has even less resistance to shaft movement than the old one (more like feeler gauge resistance when the adjustment is right) but still seems to be sealing perfectly. Not sure how to get the o-ring out anyway without damaging it, or put it back in without risking it falling into the pump chamber.
________
Oregon dispensary
rover1
Aug 27, 2007 07:23 PM
khickey
Jun 5, 2007 08:39 AM
kringkast@mac.com
Sep 5, 2006 07:18 PM
benz_tweaker
Jan 2, 2006 07:14 PM
guidomut
Sep 25, 2005 06:48 PM
