engine heater size
Old Nov 27, 2025 | 01:48 PM
noswendel's Avatar
Default engine heater size
I have a circulating tank heater and wonder if it is the right size for my240d. The cooling system is 12 quarts and the heater is 850 watts. Thanks.
Old Dec 17, 2025 | 09:25 AM
vapofi's Avatar
Originally Posted by noswendel
I have a circulating tank heater and wonder if it is the right size for my 240D. The cooling system is 12 quarts and the heater is 850 watts, or should I check with a BMW Service Mooresville to confirm compatibility? Thanks.
An 850-watt circulating tank heater is generally adequate for a 12-quart cooling system like your 240D. It should be able to warm the coolant effectively without overloading the heater. Keep in mind that heating time depends on ambient temperature, but for typical cold-start preheating, this wattage is sufficient. Always make sure the heater is fully submerged in coolant while operating and never run it dry.
joemal
Nov 23, 2007 09:44 AM
joemal
Sep 4, 2007 06:20 PM
timclark
Jan 29, 2007 08:46 AM
BrendenD
Oct 21, 2006 01:05 AM
R129
Jul 2, 2005 12:38 AM
