compression on a 240D
Old Jan 5, 2005 | 09:04 PM
gavinbr's Avatar
Default compression on a 240D
hello,
i have low compression on my 1982 240D with 250K miles
how do you tell which is the problem, valves or rings.
any suggestions would be appreciated
brian
Old Jan 5, 2005 | 10:54 PM
pberku's Avatar
Default RE: compression on a 240D
Put about a teaspoon of oil into each cylinder (one at-a-time), and measure the compression again. If now, it significantly increased, than its your piston rings. If no change, than most likely its your valves, or a valve adjustment is required.
Phil
RORENICK
Jul 25, 2012 03:51 PM
dvdiesel
Feb 25, 2009 08:19 PM
allan l
May 14, 2005 01:00 PM
big jesus
Mar 4, 2005 02:11 PM
R129
Nov 11, 2004 11:23 PM
