Changing brake pads
Old Nov 29, 2007 | 07:49 PM
rover1's Avatar
Default Changing brake pads
I have just looked at the manual regarding changing the pads on my 1978 300CD. How likely is it that I will need specialty tools. I have changed disc brake pads on numerous other vehicles, with only basic tools. Is this that much more challenging?
Old Nov 30, 2007 | 12:27 AM
Mr.47's Avatar
Default RE: Changing brake pads
I dontknowabout the front brakesbut therear i used the following:
A hammer
A smallscrewdriver (use to knock out the pins allthat holds the pad all the way out)
A C clamp
bacially BASIC tools
Old Dec 11, 2007 | 10:02 PM
disbo's Avatar
HI, I just put on new pad on my 83 300SD. Piece of cake. If you are just looking at the book pull the tires and look to see how much pad you have left. Depending on your braking style you may not need them yet or way over due. Either way its a very simple job.
Good luck Chris
forbes50
May 6, 2015 04:24 PM
sumguy7
Aug 25, 2008 06:00 PM
Kang61
May 6, 2008 01:01 AM
not a ninja
Apr 11, 2007 04:05 PM
kiasu
Jul 4, 2006 05:43 AM
