best fuel tank flush
Old Jul 30, 2011 | 03:35 PM
cult colt's Avatar
Default best fuel tank flush
I've recently experienced excessive diesel knock and occasional slight power loss on acceleration. I'm still getting 30 plus MPG . I've changed the filters several times and this helps temporarily. I can see tiny black flecks in the primary filter. The gist is , I'm going to remove and clean the tank. What's the best way to do this? Particularly, what liquid to flush/clean the tank with? I don't think there is any corrosion in the tank just some kind of crud. Any suggestions would be appreciated. It's a 123 240 D by the way.
Old Aug 4, 2011 | 11:52 AM
85300td's Avatar
Default ???
30+ MPG on a 240? My neighbor has an unmolested original 50k 240 car and he gets around 28 max.
Old Aug 7, 2011 | 09:00 AM
oldrebuiltdodge's Avatar
Originally Posted by ForcedInduction
Driving over 55mph drastically reduces economy due to the low differential ratio. 40-55mph is the most efficient range.
At a steady 45mph on the highway for 250 miles I measured 40.7mpg in my 300D. As I said though, any speeds above 65mph and any city driving will cut down economy very rapidly.
Are you saying that simply the higher rpm is drasticaly reducing fuel economy, or is it the engine trying to maintain that rpm?
Old Aug 7, 2011 | 09:35 AM
So basicly it's the increased load on the engine.
Old Aug 7, 2011 | 09:38 AM
My mentality is still in the stationary engine department
Dobschcan
Jun 4, 2011 07:30 AM
hornet1
Mar 6, 2008 06:36 AM
Cire
Aug 13, 2007 08:47 PM
ncipps
Mar 1, 2005 12:52 PM
