ABS ESP Traction Fault
I have a 2015 E220, with the above fault, I have changed Wheel Bearing and also ABS ring and also sensor on the front left, I am still getting the following issues,
C04AE00 The signal from component L6/1 (Left front axle sensor) is Faulty
On live data speed will go the same as other three wheels upto around 15-25mph then fault comes on and speed will show 40723mph and will stay like that until codes are cleared.
Any Advice or help would be greatly appriciated
