82 300SD Compression Specs
Old Mar 5, 2006 | 03:43 PM
libbybapa's Avatar
Default 82 300SD Compression Specs
I have a recently purchased 82 300SD and would like to do a compression check. I have looked through both the Haynes and Chiltons and cannot find a compression pressure spec. Any know what compression pressure specs are (normal, wear limit, max difference between cyl)?
Andrew
Old Mar 5, 2006 | 10:42 PM
sleepwalker's Avatar
Default RE: 82 300SD Compression Specs
all of them diesels got about 18 bar.
for as long as the difference between cylinders is not more than 3 bar.
Old Jul 5, 2006 | 03:23 PM
mdsurpre's Avatar
My new (lol) 85 300 SD Turbo runs fine, but I just had compression test done (after a valve adjustment) with poor results:
22
21
18
15
14
Factory specs are 24-30, with 18 being the minimum.
I know that these results are not good, but exactly how bad are they? Does this mean the engine is completely shot and I need to look at a rebuild? Will the car start in Michigan winters? (temps around 25-35 F)
Any advice is appreciated!!
Thanks,
Marc
lombrozo
May 27, 2010 07:16 PM
DieselRepair101
Apr 24, 2009 07:25 PM
big jesus
Mar 4, 2005 02:11 PM
gavinbr
Jan 5, 2005 10:54 PM
R129
Nov 11, 2004 11:23 PM
