'82 300D Climate Control
My '82 300D keeps blowing the #8 fuse (blower motor, a/c compressor, idle stabilization). At first, I thougt the two wires that plug into the compressor (new compressor 1.5 years ago)were touching. I have fixed that problem, but the fuse still blows. It doesn't seem to have any consistency in how long it lasts. It will blow immediately part of the time, and other times it will run for a day or more. It doesn't matter if it is in heat or a/c mode either. Does this sound like a simple short in one of the wires, or is there something else I should be investigating, and how should I test it? Thanks for your help.
Having the same problem with an 85' 300TD, if you get any ideas on what to do will you please keep me in the loop. It sounds like the same issue, I had just given up it go so pricey and time consumming. Thanks so much for your post.
norcal1440
09-09-2014 12:29 PM
