300SDL fuse problem!!!
Hi
i got a 1897 300SDL, and the problem is that fuse # 15 (central locking, alarm, delayed doorlight and more that i dont remember) keeps on blowing out, within hours..... what can i do to slove the problem, and what's causing it???
thx
thx
Sounds like you have a live wire grounding out and blowing the fuse. Get out your wiring diagram and trace the wires. Especially check out any aftermarket wiring that may have been done/spliced in with that fuse. I had the same problem, where I did some "custom" wiring in my car. Everytime I went over a big bump in my car, the hot wire would ground out against the frame and cause the fuse to blow...
Wisjd
Feb 1, 2009 12:13 PM
