300d Transmission compatibility?
hello all,
i have a grey market import 1984 300D with the automatic 4 speed transmission (which died and has been removed)
the original transmission is stamped with this:
1232705601 722.405 02 072250
i am leaving college thursday morning, and have found a transmission on the way home at a junkyard. 139,000 miles, grade "A" (less than 15k per year), this transmission has these #'sstamped on the side:
1232705901 722.315 02 505438
will it work in my car? they both have a mechanical speedometer sensor.
a quick response would be much appreciated
thanks a bunch
-justin
thanks a bunch
-justin
On the left side of the transmission (drivers side) there is a round plastic (normally green in colour) modulator with a vacuum line connected to it. What I would do is do the swap and make sure all vacuum lines and linkages are properly connected. Fill the tranmission with fluid, then take it for a short drive. If your shifts are harsh, then there is a "T" **** on the modulator - turn it counter clockwise to soften the shift. If the shift is too soft or feels like it is slipping, then firm up the shift by turining the **** clockwise. Do this in small increments.
I have an 1984 300d and the tranny has stopped moving the car forward reverse is fine. It will go but only if you rev it up. I the option of a free 1981 300d wagon, will the tranny bolt up if i need it.
#9
I am looking to find out what's compatible in my 86 300SDL (greasel) and found this link, but it doesn't mention the SDL, maybe it can help someone else. http://www.jpat.co.uk/Mercedes%20tra...0reference.pdf
