1982 240D Issues...Need Some Help
Old 07-15-2017, 08:34 PM
teddyd49's Avatar
Exclamation 1982 240D Issues...Need Some Help
thanks in advance for any leg up you might be able to provide....
I have several issues with my 240D sedan...it's no wonder as it's 35 years old....lol
1) turn **** below instrument cluster that controls cluster lighting brightness and which one pushes in to reset odometer is no longer working...it appears to have worn out and/or become detached from its base inside the console.....is there a quick fix/part replacement that will fix this problem?
2) fixed "vacuum" leaks several years ago....these have returned....car locking mechanisms not working properly from master control regulator (recently replaced) inside driver side front door...also engine fails to shut off immediately when ignition is turned off with key...need to depress clutch in order to shut down engine...any ideas on where to look for the problem?
3) have a short somewhere in the electrical system...this manifests itself now with the "reverse" tail lights not lighting up when car is put in reverse....also have one broken license tag light fixture which I have ordered to replace the old one....awaiting the part....does this signify "where" it might be that the short can be found without going through the entire electrical system?
I love my car but it is a constant battle to keep up with the repairs that crop up on this old darling....any guidance would be most appreciated...thanks.
Old 07-17-2017, 03:33 PM
Hello Teddy - I'm attaching a link to our site's DIY tech articles on the W123 platform that I think you'll find very helpful when doing any maintenance or repairs on it. For part numbers, feel free to give us a call at 888-280-7799 and one of our MB part specialists will be happy to help you out. Hope this helps and best of luck!
Mercedes-Benz W123 300TD (1977 - 1985) Technical Article Directory | DIY Maintenance and Repair Projects for MBZ 230, 240D, 280 CE, 300D, 300TD | Pelican Parts
teddyd49
03-09-2016 03:30 PM
joewaldrop
01-04-2009 08:43 AM
machume
07-21-2008 10:20 PM
gslama
06-27-2007 09:58 AM
Quick Reply: 1982 240D Issues...Need Some Help
