1983 300D Auxilary Fan Questions - Help!
Hi All,
Yesterday my 1983 Mercedes 300D started running hot. Today I noticed the auxilary fan was not working. I checked the fuse and it has juice going through. I even noticed the fuse was hot with a cold engine and key off... Is that normal? Before I get one on EBAY (Does anyone have one on the list?) can I run wires directly into the fan plug to test it? Will that cause any harm? Anything else I should check? Suggestions are greatly appreciated! Bobby Koziak 1983 300D 112K |
RE: 1983 300D Auxilary Fan Questions - Help!
You should not have a hot aux fan fuse if the key is off. Yes, you can run a + and - wire from the battery direct to the aux fan at it's plug to test. Brown wires in a benz are always negative.
Common problem with aluminum fuses on copper (brass) fuse holders.
Someone on ebay was selling copper fuses for Mercedes. Clean the connectors well. After 20+ years they have the right to have some dirt on them. |
