-   Diesel Discussions (https://mercedesforum.com/forum/diesel-discussions-33/)
-   -   1982 240D, engine wont turn off. (https://mercedesforum.com/forum/diesel-discussions-33/1982-240d-engine-wont-turn-off-43843/)
nicorahiah Jul 31, 2010 05:28 PM
yesterday i went to jiffylube to get my oil changed, (i've had this problem before) and i guess they knocked a hose or something or one of my golf Tee's (what i use to close some tubes with) fell off. now my engine wont shut off. all the electrical turns off, but according to my dad, the vacuum system is sitll pulling gas to the engine, thus why it wont turn off. my dad who fixed this before just closed off the hoses that werent connected to anything and it shut off fine. but i cant find anything that isnt connected. im not very familiar what what should be connected to what or closed off, so if anybody that has any experience with this please lend your advice :]
i also took a few pictures, and i can take more of specified areas if needed.
these are the tubes that are generally plugged. im not sure of the long brown one, but my dad said there should be multiple golf tees in this area and i only saw one, so i plugged that one as well. and i have no idea what that yellow thing is, but im pretty sure it was never plugged Dx
http://i25.tinypic.com/2dubj7r.jpg
and this is something i havent noticed before, it looks like something should go into it. but it could also be totally irrelevant :l
http://i32.tinypic.com/1zf26hh.jpg
nicorahiah Jul 31, 2010 06:25 PM
im sorry, im having trouble understanding :\
http://tinypic.com/r/211lcaa/3
maybe you could point it out on this picture? xD
nicorahiah Aug 1, 2010 06:31 AM
but that wire is plugged into something o.o so it should be working.
im referring to this wire thats not plugged into anything;
http://tinypic.com/r/2gt7o9e/3
wrecks79 Aug 1, 2010 10:52 AM
I'm sorry but you can't plug those vacuum lines and expect it to function properly. Everyone of those lines have a job to do. hook em all back up and then troubleshoot. Otherwise your just assumeing. Do you think the moco. would waste money on something the car really did'nt need ?
nicorahiah Aug 1, 2010 01:26 PM
thats the problem! D:
i dont know where any of them go, plug into or what they do.
and i wanted to know if one of them is the reason for my car still pulling gas to the engine. specifically the unplugged ones because this happened after an oil change.
wrecks79 Aug 1, 2010 02:50 PM
The hoses are cut to fit, just hook them up where they fit comfortably. Unless you get a diagram of the vacuum hoses, you'll have to trial and error it. But remmember they are cut to fit so they should pretty much fall into place.
wmjodea3 Aug 1, 2010 07:21 PM
My son's 240D had this problem and it turned out the AC vacuum hose (the green line) was leaking. Also connect the plugged hose which has the brown and green line to the yellow vacuum check valve.
This link might also help you:
http://www.peterschmid.com/vacuum.htm
http://www.peterschmid.com/vacuum/19...616_617_91.jpg
