"Block Heater"
Where is it installed or suppose to be installed? How do I identify it? If it's not installed is it difficult to do?
RE: "Block Heater"
I see the freeze plug and it does look a bit corroded. I just don't understand how the hose heater keeps the engine block warm to aid in "cold starting" the vehicle.
RE: "Block Heater"
I was under the impression that the "block heater" warmed the air inside the block. I didn't realize that it was warming the coolant....thanks.
RE: "Block Heater"
Hose heaters don't work as well/efficent, but are much easier to install. Hooked to the lower rad hose the heated coolent rises and keeps the block warm for easier starting plus faster heat in the cabin.
RE: "Block Heater"
Found out that my block heater still works. Will it just keep heating the coolant or will it maintain a constant temperature when reached?
RE: "Block Heater"
ORIGINAL: ForcedInduction It will be on as long as its plugged in. |
RE: "Block Heater"
Yup, left it on for nearly 48 hours. Started right away, reached normal op temp 1/4th the time. Sure is a big help this season.
