Detailing Discuss detailing your ride inside and out here.
Proper washing techniques.....
Old Jan 14, 2005 | 03:24 PM
exceldetail's Avatar
Default Proper washing techniques.....
I thought I would start a thread entitled Proper Washing Methods. I ve been reading some threads on other forums, its amazing how people wash there cars, and what they use ! So lets get started: The first thing you would like to do is pick a shaded area, this will help in permitting water spotting later. Items you will need for this venture are : 2 buckets, car wash, sheepskin mitt or microfiber mitt/towels, waffle weave drying towel, wheel brush, hose nozzle, a safe wheel cleaner, maybe some tire cleaner. Some folks like to clean wheels first, so I wont get into the particulars of that, its fairly easy, and basic. Apply a safe wheel cleaner, to one wheel at a time, clean with brush or suitable cleaning tool, rinse, continue to the next. lol
While your car is cool, and hopefully in the shade, start hosing the surface off with a high stream of water, start at the top so dirt and contaminants fall over non rinsed areas. Make sure to use a good stream to any side moldings and emblems, you will be amazed at the quantity of dirt hiding in there.
Continue to do this until the entire surface has been rinsed. Remember, top to bottom.....Next add a couple oz of car wash soap to bucket #1, and fill with water, add water to bucket #2. With the sheepskin in hand, or whatever you’ve selected to wash with, gently wipe the surface with suds from a front to back motion, again, your starting at the roof area, then trunk, then hood, then sides. Depending on your speed, and if it is warm and dry out, you may need to rinse each panel after washing, until you have completed the car. Keep your cars surface wet until your completely finished. When you find the need to redip your sheepskin in the suds, rinse it out in bucket #2, this will remove dirt and contaminants from possibly further scratching the surface. (Your going to want to make sure you have plenty of soap (lubricant) on your sheepskin all the while washing, this will help to suspend the dirt, and let it be carried off during the rinse.)Use that method throughout your washing. After the vehicle is completely finished, remove the nozzle from the hose end, and let the water exit the hose without any added pressure. Hold the hose a couple inches from the roof surface, and start at the high end of the vehicle. Chase the water across the surface with the flow exiting the hose. Run/sheet the water across the surface, and continue with the hood, and rear deck, and sides.
When all is said and done, open the hood and trunk, and let the remaining water sheet itself off while you dry the sides with a Waffle Weave drying towel. (At this point, some like to use quick detailers or Eagle One’s “Wax as u Dry”.) Start at the top, and work your way down to lower panels, refold the waffle weave as it absorbs water, a 24x30 towel is generally all that is needed. You may want to follow in your other hand with a clean and dry microfiber 16x16 towel.
You may find this technique of benefit to you, and if so, you may be able to tweak it a little to meet your specific needs. Good luck, and I hope to have helped at least a few of you !
[IMG]local://upfiles/2220/82146651BEF44DAA8E871F5710FEBF27.jpg[/IMG]
[IMG]local://upfiles/2220/8B22170D2EB14D47BEB0C1E6C7C42B36.jpg[/IMG]
[IMG]local://upfiles/2220/D2DBD77AC06A4222B12C83F20E39D0F5.jpg[/IMG]
[IMG]local://upfiles/2220/97E0D901B8A6455B8723BAB74402F979.jpg[/IMG]
exceldetail
Jan 11, 2008 12:23 PM
Autogeek
May 16, 2006 03:00 PM
Esteves
Nov 30, 2005 03:48 AM
exceldetail
Dec 13, 2004 04:08 AM
exceldetail
Nov 12, 2004 12:40 AM
