Audio/Visual Electronics Wired up? Got a cool radio? Everyone's got some sort of electrical modification. let's hear about it.
C200 K Coupe & Nokia 6310i
Old Aug 18, 2005 | 11:52 AM
PhotoPix's Avatar
Default C200 K Coupe & Nokia 6310i
Hi all, just got a used C200k Coupe with a MB car phone kit installed. I bought a used Nokia 6310i and when I attach it to the car all I get on the instrument panel display is "processing" Does the phone need time to upload it's data to the car or does my phone have older firmeware and need to be updated?
Old Aug 18, 2005 | 11:57 AM
sleepwalker's Avatar
Default RE: C200 K Coupe & Nokia 6310i
even after two minutes it's still the same? even if you dial a number?
you're putting it on the cradle? maybe the phone is faulty?
Old Aug 18, 2005 | 12:37 PM
C280 wizard's Avatar
I have the same phone, I use it without any connections to the car, I have a case to hold it's velcro'd to the side of the console and use a earpiece and mike combo. Screwing around with the electronics is a bad idea. Mercedes warns you not to use anythin but there product, I never had a problem with my cellphne.
Old Aug 19, 2005 | 11:10 AM
PhotoPix's Avatar
Thanks, I just found out that my 2002 model C200k only supports the Nokia 6210 (not so good)
and would need a new in car control unit (very expensive) for a 6310i.
So unless anyone has any other ideas it looks like I wil be having a buy/sell session on ebay!
Old Aug 19, 2005 | 11:24 AM
your datacard got 854
Old Aug 22, 2005 | 10:34 AM
PhotoPix's Avatar
sorry don't understand what you mean?
ORIGINAL: sleepwalker
Old Aug 22, 2005 | 01:02 PM
you can only use 8210.
if you'll give me your VIN, i can explain more.
Old Aug 23, 2005 | 08:00 AM
PhotoPix's Avatar
don't you mean 6210
Here is my VIN
WDB2037452A332116
thanks
Old Aug 24, 2005 | 12:57 AM
  #9
okay, that's it. it is very clear now.
your take-up device is located on the dash and not on the center console... right? (figure 180).
according to that pick-up device, the phone that you can use is Nokia 6310i... since you got no 854 code but 852 instead. sorry about the mix-up since i was only basing according to your explanation instead of your DATACARD.
[IMG]local://upfiles/1/70913BD413994E24BDF589FC7EB2C756.jpg[/IMG]
Old Aug 24, 2005 | 01:07 AM
  #10
[IMG]local://upfiles/1/8C12671A313743A08F83800643BF0080.jpg[/IMG]
[IMG]local://upfiles/1/FE14570CE1194F9AAB7FA91D8B10674E.jpg[/IMG]
