Audio 5 for A-Class without connection?
I don't know if the device I use to play my MP3 player. I have a "Road Trip" FM Modulator. If any of you are members of MBCA there was an artilce on this device. It plugs into your cig ligher, like a phone charge and looks the same, but it has a FM modulator built into the plug. the other end has a male plug to plug into 99% of MP3 players. On mine you set the radio to FM 107.7 mhz. They has have one set at FM 88.7 mhz. The maker will sent the one that works best in your area. Believe me this device is wonderful, the MP3 player when turned on to play sounds wonderful. I keep the MP3 player in my C Class in the small shelf above the ashtry. You can also hard wire it, if you can a shop familiar with such work. The company also carries devices to hook up most type of electronice via your lighter. One thing I do, I also disconnect the player and put it in my pocket, noisy people, if you get my drift. The best part this device cost $15.00. I highly recommend for you music nuts like me. Below is the website address.
ww.newtech.com
ww.newtech.com
old benz
Mar 1, 2006 02:55 AM
