tonight my ML320 broke - drive train ?
Old Aug 24, 2010 | 06:51 PM
sdanville's Avatar
Default tonight my ML320 broke - drive train ?
1999 ML320 160,000 miles. was on the xway and got a shimmy, then a shake,
then I smell rubber with a metalic noise .....
I pull over check for the obvious. nothing.
drive another 10 miles,,,it gets worse and worse. I cannot drive it anymore.
I am hoping I threw a belt in a tire. It seems maybe more towards the rear.
So I put the spare tire on RR. No change.
I put the spare on LR no change.
I drove in reverse no change . still shaking horrible.
got going 5 mph and it shakes like a drive shaft is way way out of balance,
I put it in neutral no change, Still shakes. A friend came, he looked and we cant see anything wrong. I have to have it towed to a repair place in the morning.
I have fixed everything myself for 70,000 miles until now. I am stumped.
I do not do transmissions, Thats where I draw the line. I have replace several drive axles.
Anything come to mind ?
Old Aug 26, 2010 | 07:58 PM
sdanville's Avatar
Default CURED drive shaft center BEARING.
I paid $220 OEM bearing and $80 for 2 bolt installation.
the drive shaft centering bearing went bad. You can buy them on Ebay for $40.
If I would have been close to home I could have fixed it myself. I wasnt.
Old Aug 26, 2010 | 08:48 PM
those bearings can be a bear..especially trying to get the 2 bolts that hold it in. sometimes pulling off the bearing is a pain too. if you have a lift it isnt to bad but i wouldnt want to do the job without one. dealer charges about 4 hours to do the job
SteveCollins14
Jun 26, 2014 11:56 PM
Corstrat
Nov 19, 2011 03:28 PM
rd92171
Jan 17, 2006 09:13 PM
stephen
Mar 14, 2004 06:31 PM
Kambiz
Dec 27, 2003 12:02 PM
