Help!! C280 transmission in limp mode
Old Jul 29, 2010 | 08:30 PM
arkamedies's Avatar
Default Help!! C280 transmission in limp mode
I was just driving around, I was sitting at a stop sign. I accelerated so I could get in front of someone, nothing crazy. Then the tranny won't shift at all. I pulled over and turned it off, then turned it back on. The check engine light turned on, but the tranny is still in Limp Mode. What can I do? Everyone I called wants like a hundred bucks just to read the error codes.
Old Jul 29, 2010 | 11:51 PM
JimP's Avatar
Are you still under warranty?
Old Jul 30, 2010 | 05:38 PM
arkamedies's Avatar
Nope, otherwise I'd just take it there. It's up to me figure this out. For what reason would the transmission go into limp mode in the first place? I honestly have no idea why this is happening.
Old Jul 30, 2010 | 05:45 PM
BMWMotorad's Avatar
If it's like my Ford truck, you can disconnect the battery for 10 minutes or so and it will reset. It should go out of LIMP mode. This won't, of course, tell you what happened, but you could try it and see if it goes back into limp mode. If it does, it will tell you that you definately have a problem. I know you'll also have to reset your sunroof after you disconnect the battery, and I'm not sure what else, (I've been a MB owner for all of two weeks now) but it's worth a try.
Old Jul 30, 2010 | 11:50 PM
jmsbiz's Avatar
Help!! C280 transmission in limp mode.
Reply: More than likely it is the MAFS (Mass Air Flow sensor) causing the problem. Take it to an Autozone parts store and they will read the 'check engine' codes for you. Then come back to this forum with the codes and do a search.
Good luck.
John
Old Aug 2, 2010 | 09:06 PM
arkamedies's Avatar
The codes that came up were:
PO715
PO720
Where do I search? I don't see any sticky threads on this board
Old Aug 3, 2010 | 12:13 AM
Schwarz_Rot_Geil's Avatar
Could be that your catyllitic convertor box blew out. I did the exact same thing racing a Jeep in my M-class (lol, embarrassing yes I know) and I couldn't drive past first gear. It wasn't cheap to fix, but it's something that shouldn't happen again throughout the time you own the vehicle.
Old Aug 3, 2010 | 11:52 AM
Icebreaker's Avatar
A catalytic convertor box blew out???? Are you talking about a torque converter? A catalytic converter is part of an exhaust system......
Alan.
Old Aug 3, 2010 | 07:31 PM
arkamedies's Avatar
Indeed, his post makes no sense. But I would like to know more information about these codes and what they could indicate, if anyone has any idea please post them.
Old Aug 4, 2010 | 06:05 AM
JimP's Avatar
Where would you find these codes interpreted?
