"airmatic" is it time to change the sensors?
Old Jul 20, 2010 | 06:30 AM
burg boi's Avatar
Default "airmatic" is it time to change the sensors?
Hello Forum,
Each morning for the past week ... my right rear fender has pratically sat on my tire ... the good news ... once i start the car, it takes 8 seconds or less to self correct after the "stop! , car too low" signal comes on then disappears ....
Today, while driving, the "stop!, car too low signal came on", Oh , oh ...
I have a button on the dash that allows me to "manually" raise the car!
So far ... if i use the manual raise after the car automatically resets ... i seem to have eliminated the problem ... for that drive, lol; is some air "leakage" acceptable ... does extreme temperatures have any effect or IS IT TIME TO SERVICE THE VEHICHLE ???
Old Jul 30, 2010 | 04:37 PM
silver seattle s5oo's Avatar
this sounds like 1 of 2 possible issues. I doubt it is a sensor. I bet the air shock in the back is going bad and leaking. They aren't too bad to replace. I had a similar issue and was able to resolve it for a bit with the dash button, but then it stopped functioning as well. For me it was the air compressor in front that was bad. 700.00 to replace at a local private MB shop. since you just have one corner, it might just be that shock. I would replace it ASAP, because I think the pump can overheat from too much use to maintain a leaky system. I found several on e-bay for ok prices.
cokochanel
Sep 18, 2011 08:10 PM
raltherr
Nov 21, 2010 10:23 AM
sonnyfp
Nov 3, 2010 12:04 AM
mb298
Jun 21, 2010 09:33 PM
PeterTaps
Feb 7, 2010 03:20 PM
