Transmission Problem SL
Old May 27, 2010 | 07:10 PM
alanelpc's Avatar
Default Transmission Problem SL
My 91sl500 would not shift into 2nd and the mechanic said to bring it in, and during the drive, not to take it above 3000rpm. Upon inspection he said I had dirt in the shift valve but the fluid was very clean. Next day he called and said he cleaned the valve but that was not the problem, I needed a new transmission. Still, after the new transmission, the car is doing the same! It will not shift into 2nd until a little over 3000 rpm. After that, when it's warm, it is fine, and shifts fine for all additional trips that day. However, the power I used to enjoy is gone - it's like the car has been castrated. After the new transmission, I have taken it back twice, the mechanic says he cleans the shift valves, but the next morning (while cold) it does the same. I am out $3000 and the problem is not solved.
surf077
Jun 21, 2005 12:49 AM
mexicocrow
Feb 2, 2005 03:17 PM
billaq
Nov 14, 2004 09:24 AM
89190e
Aug 15, 2004 07:15 PM
KELBEL
Jun 25, 2004 10:10 PM
