FS Late 129 SL Brembo frt calipers
Old Nov 18, 2009 | 11:42 PM
salvine's Avatar
Default FS Late 129 SL Brembo frt calipers
I know, first post here. Been active on the BMW boards for quite awhile. 99 SL frt brembo calipers. I good condition. All seals and boots are flawless. There is some clear coat chipping off that can be seen in photos. These are the calipers that fit all 129's, V-8 124's and 201's if you are running 17 inch wheels or larger. They use the 334x32mm rotor off of late SL's. You can get these in standard or drilled versions from the dealer. Awesome brake upgrade using factory parts. 13 in rotors! Asking 600.00 with all hardware and a good set of OEM pads. Shipping included in conus.
Attached Thumbnails FS Late 129 SL Brembo frt calipers-img_0270.jpg   FS Late 129 SL Brembo frt calipers-img_0271.jpg   FS Late 129 SL Brembo frt calipers-img_0272.jpg   FS Late 129 SL Brembo frt calipers-img_0273.jpg   FS Late 129 SL Brembo frt calipers-img_0274.jpg
gsxr
May 23, 2008 10:54 AM
Juel
Nov 21, 2007 01:44 PM
LVDOC
Jun 22, 2007 10:09 AM
sgarcia89lx
Feb 27, 2007 02:05 AM
tacofuel
Dec 6, 2004 02:21 PM
