Help.. Need fuse diagram for 2002 c230 coupe
Old Oct 27, 2009 | 05:57 PM
Laidbackkat1's Avatar
Default Help.. Need fuse diagram for 2002 c230 coupe
Hopefully someone has this... I have the hatch back and it's differant from the sedan.. There is no driverside cockpit fuse panel that I can find.. I disconnected the ground side of my battery to try to get rid of a check engine code .. stupid... atfer that I had to rest/sync the windows, roof, esp.. the remote locking system doesn't work now.. it locks vie the button in the car but not by the remotes.. I have tried both remotes and they apear to work/flash etc... I am concerned that I may have damaged the rear sam after reading several posts.. I have checked all the fuses I can find but I don't know which on is for the doors/security system.. If this is the sam can I buy one on ebay from a junker and put it in ??? any suggestions would be appreciated.. I would take it into the dealer but I lost my job 2 months ago.. weee this is fun.. Ron
Old Oct 27, 2009 | 10:40 PM
gilgorm's Avatar
I have owned this identical car since new.
If you have the manual refer to page 311.
If not, there is an inside drivers side fuse box. Open the drivers door and look at the end of the dash. There is a large triangular shaped end cap for the dash. From the manual--"Pull cover away from fuse box and remove rearward." The fuse chart is inside.
I assume you found the engine compartment fuse box against the firewall on the drivers side. It is located under the rain diverter "cover" that is simple to remove. Then release the metal clamps and remove the cover.
There is also an auxiliary fuse box in the trunk on the drivers side close to the taillights.
Undo the small handles and swing open the cover panel. The special fuse puller is located inside with the fuses.
Old Oct 28, 2009 | 01:35 PM
Thanks .. I found it with your help..
AMGFAN1
Nov 30, 2008 10:39 PM
Jeff240000
Oct 26, 2008 05:55 PM
aesop00019
Oct 4, 2008 04:25 PM
Maggie
Mar 27, 2004 07:41 AM
Maggie
Mar 26, 2004 10:51 PM
