79 300SD engine won't shut off
Old Oct 27, 2009 | 02:32 PM
drifterdan's Avatar
Default 79 300SD engine won't shut off
I am new to Mercedes. I just got a 79 300SD. The engine stays running when I shut off the ignition. Any info on how to fix? Thanks.
Old Oct 28, 2009 | 06:51 PM
drifterdan's Avatar
Default Drifterdan
Thanks for the info.
Old Oct 28, 2009 | 09:55 PM
Diesel9112's Avatar
To see if the Vacuum Shutoff on the IP works and you do not have a Vacuum Tester you can actuall hook a piece of Vacuum Hose to it and suck on the end. If it shuts off like that there is a good chance the Vacuum Shutoff is OK and you have a Vacuum Leak Problem.
If it is not a hose or hose connection and you believe your Vacuum Pump is working OK (your Power Brakes would be working OK) there is another Shutoff valve attatched to the Steering Wheel Lock. It also has hose connectors to check there that can go bad and the Valve itself can also go bad (the valve cost about $25 for my year of car).
DavidYon
Dec 14, 2011 12:09 AM
moondoggy
May 4, 2008 07:20 AM
gm55
Apr 28, 2007 10:53 PM
dsalustri
Nov 2, 2006 04:02 PM
amore76
Oct 25, 2006 01:36 AM
