2002 ml320
Old Aug 20, 2009 | 11:27 PM
thomasjohn's Avatar
Default 2002 ml320 - CD Changer not working
My CD player stopped working. So, I opened the cd Changer and try to eject it. But it did not work. So I unpluged the wire to reset it. After I plug it back, it seems ok. Now there is power on the unit and is able to insert CD.
However, When I select CD on control panal, it is saying ''no cd installed''.
There is power in the CD changer unit and is able to take out the cd and insert.
Please suggest how to fix this problem.
Old Aug 21, 2009 | 07:24 AM
My guess would be bad connection by the CD changer or behind the main unit in control panel.
Old Nov 20, 2009 | 02:17 PM
wsturg's Avatar
there should be a number that you input into the radio and the CD is then recognized. happens when you disconnect the battery for any period of time.
Old Nov 20, 2009 | 02:57 PM
What you are talking about is a security code for your radio to even start working. I believe that has nothing to do with the CD changer recognition.
speedcheese
Sep 10, 2007 08:39 PM
Patamdar
Jun 30, 2006 04:45 AM
jlindy
Mar 7, 2006 06:22 PM
croat
Sep 29, 2005 11:38 PM
speedcheese
Sep 26, 2005 08:49 AM
