Front Brake Rotors
Old Jul 2, 2009 | 08:51 PM
guypatterson56's Avatar
Default Front Brake Rotors
I have a 98 E320 and need to replace my front pads and rotors. The front calipers look pretty straight forward but the rotors are another matter. After removing the hex set screw from the rotor, I cannot determine where the rotor breaks away from the hub. Their is a cap that covers the hub but I don't know if you have to remove it. If so, does it screw off or require a special wrench. Most rotors I have replaced you can bump off the rotor once your remove the caliper. Any help hints would be helpful.
Old Jul 2, 2009 | 08:59 PM
yes remove caliper and then the rotor screw, then hit the rotor with a large hammer
Old Jul 2, 2009 | 09:35 PM
Default suggested rotor and pads
I noticed that my rotors are pretty scored and have an edge on the outside and inside track of the rotor. Not sure if that is normal. Do you suggest replacing both pads and rotors at the same time rather than turning the rotors? If so, can you point me to a good priced source for pads and rotors.
greenl
Mar 15, 2012 05:19 PM
WMJ-CLS500
Oct 12, 2010 07:09 AM
perrib
Sep 5, 2009 05:26 PM
allyreese
Nov 23, 2007 02:00 PM
darqlorde
Jun 28, 2004 10:53 PM
