Location of diagnostic connector please
Old Jun 28, 2009 | 03:54 PM
mercfancy's Avatar
Banned
Default Location of diagnostic connector please
Hello everyone,
Could someone help me to find location of diagnostic connector on 200slk avantgarde, year 2000?
Thank you all:confus ed:
Old Jun 28, 2009 | 07:59 PM
the mercedes connection is under the hood. pass side. under the round cap. and the other connection is under the dash driverside.
Old Jun 29, 2009 | 04:35 AM
mercfancy's Avatar
Banned
Default diagnostic plug located
thanks for your response back, i have succesefully menaged to find it. I was expecting to be the obd2 16pin connector, and have looked almost everywhere inside the cabin.
Once again, thank you
Old Jun 29, 2009 | 08:54 AM
mercfancy's Avatar
Banned
Default slk200 2000
hi chassis221,
just out of intrest, do you know anything about 200slk kompressor, year 2000?
are the engines and manual gearboxes reliable at all?
have good day
Old Jun 29, 2009 | 06:22 PM
i cant tell you about the 200 engine because i dont have experience with them. what ive seen from the manuals is good. only seen 1 that wouldnt go into gear. but here in USA there arent many manuals around they are all automatics. here in the US the slk have issues with water leaks and side window alignment, and water in the trunk.and also the peeling paint on the interiors.
Old Jun 30, 2009 | 09:30 AM
mercfancy's Avatar
Banned
Default slk200
hi chassis,
yes you are absolutelly right there, we in uk have same problem with interior and exterior trims. Specially external bodywork, corrosion appears from nowhere, the most common to place to find corrosion is on tail gate where the lock is and qourter panels??? makes you wonder expensive car with annoying extra thin layer of paint!.
One i am looking to purchase has solid roof so i dont think i have to wory too much about internal water leak.
Once again, thanks for your personal view on slk200, year 2000
you the star!
CrazyJane
Sep 3, 2015 12:35 PM
cckcheng
Mar 19, 2007 02:36 PM
sampatvijay
Sep 20, 2006 05:22 PM
muso58
Jun 14, 2005 01:47 PM
ffr1222k
Jul 17, 2004 12:52 PM
