Doors wont unlock/lock!
Old May 12, 2009 | 01:49 PM
mjnt's Avatar
Default Doors wont unlock/lock!
hi, i drive a 2001 s500. just like usual, I press my key remote to unlock my car, the light flashes but the door wont unlock. have to use the key in the remote to get in. does anyone have similar problem happen to their cars before? what is the problem? first i though is the battery of the key but its just replaced. also before the doors of the car will automatically shuts it all the way when it is not tightenly closed but now it doesnt do that anymore. can figure out whats the problem. thx in advance.
Old May 16, 2009 | 02:36 PM
cool's Avatar
check the fuse on the rear compartment/trunk fuse number 19 if fuse is ok take put it back and it will reset and for the central locking the pump is located underneath the rear passenger seat right side.
Old May 18, 2009 | 07:31 PM
mjnt's Avatar
^thx, i will check it out now!
Old May 19, 2009 | 02:41 PM
cool's Avatar
next step is to check the vacuum tube line is any is disconnected/loose/broken
Old Oct 31, 2009 | 06:37 PM
mbgirl00's Avatar
Default Newbie!
Hi all,
I have the exact same problem with my car. Does anyone know if the OP figured out the problem or solved the problem??
Thanks in advance!
Old Nov 15, 2009 | 12:54 PM
S600moneypit's Avatar
i have a 2001 S600. my car does this all the time when it gets cold out haven't been able to figure out why. but if you sit in you back seat on the right side (passengers side) right behind your feet there is the light that lights up the floor. remove that light and there is a fuse panel in there. its a 30a fuse just replace it and you will be all set until it blows again. if anyone knows why the fuse blows when its cold out that would help me out greatly
Old Nov 16, 2009 | 10:12 AM
mbgirl00's Avatar
Thanks s600! I have not tried that but I will. When I took it to the dealer they said they checked the fuse, I am thinking the one in the trunk?
I am in Houston and it is no where near cold here, but I will try anyway. I just find it strange that after my battery died that the doors stopped unlocking and the auto shut stopped as well.
Old Nov 17, 2009 | 01:08 PM
you should have posted that info when you made the thread. mine started messing up when my battery died and i had to jump start it. i went to mb but they had no clue. they are the biggest group of idiots i have ever met. the trunk is on that fuse also. it is 100%that fuse. change it and you will be good to go
Old Nov 18, 2009 | 08:59 AM
mbgirl00's Avatar
Thanks for the information. I will try the fuse this weekend and let everyone know the outcome, just in case someone else is having this problem.
Old Apr 16, 2011 | 03:47 PM
ELS-V's Avatar
Default Drivers Door only
I have an '03 S600 and my drivers door lock is not working along with the automatic closer. From what I am reading, it doesn't sound like the fuse but maybe the vacumn line. Does anyone know where I would check it at?
