300E parting out
Old Aug 24, 2008 | 12:08 PM
Hanno's Avatar
Default 300E parting out
Phase 2: Many parts sold through first posting (Thanks!), but many still available.....Parting out a 1988 300E W124. Most parts cross 1986 through 1989, some through 1995. Most will also fit a 260E. Was a good running motor (has had valves and head done). Most everything available and cheap, as in...Window regulators $45, sunroof motor $50, seat motors, $10, owner’s manual $4, radio $50, FI ECU, $20, black dashboard (no cracks) $150, engine wiring harness, $45, etc., etc. These are DELIVERED PRICES in the 48USA. Most electrics, relays, glass, doors, fenders, trunk, sunroof, switches, suspension, gauges or cluster (temp display does not work), stock wheels (cosmetically poor) but w/good tires, trim (interior and exterior), airbag and sensor, steering wheel and adjustable column, outside mirrors, first aid kit, and most all the other parts. Its arctic white (#147) with a medium red leather interior (#227). Seat leather can be oiled to bring it back but driver’s backrest has a hole. Electric seat functions work, sunroof works. Has heated seats.
Let me know what you need and include a zip (or Canada postal code) and I’ll provide description/condition and quote delivered to your door, or you can come and remove your purchase (located in New Castle County, DE). Foreign shipments not a problem, but you pay your country's import tax/duty. Paypal preferred but MO OK. Contact me through PM or hanno2s@verizon<dot>net
Not available: transmission, drive shaft, shifter and surrounding trim, pedal cluster, headlight washer system, interior door trim, B pillar trim, front bumper, headlights, EZL module, fuel distributor, IAC valve, hood, LF door, grille, exhaust system, CCU, Klima relay, fuel pump relay, dash vents, headlights, front seat belts, lock set, aux. water pump, window switches from console, fader, blower motor and regulator, plus other stuff I can't remember.
Some items in process, if you don't see it, ask.
Thanks, Hanno
rmwilson
Sep 2, 2007 12:52 PM
quest55
Jul 3, 2007 01:29 PM
thegoatc
Feb 28, 2007 12:27 AM
rmwilson
Oct 5, 2006 04:00 PM
lexustrader
Nov 23, 2005 01:18 AM
