SLK 230 PSE pump
Old Nov 2, 2004 | 06:58 AM
Martin's Avatar
Default SLK 230 PSE pump
Hi Guys.....
The PSE pump has been diagnosed as being faulty on my SLK230. My local MB dealer has quoted £450 to change it for a new one.
Can anyone give me some advice about replacing this unit myself? Where is the PSE pump located in a SLK? Is it a genuine MB part or can I buy it from another source (ie. Bosch, Lucas etc.)? Does it need setting up on a diagnostics machine or is it a simple part to replace? Where can I buy the part from (I am in the UK)?
Any advice appreciated.
Martin
Old Nov 3, 2004 | 12:33 AM
Default RE: SLK 230 PSE pump
the right price is 322.50 euro if you go buy it yourself.
replacing it is very easy. it can be done with the simple tools provided with your car.
almost all of them are already coded which is not necessary to use the computer upon replacement.
i never been in UK and doesn't know where to buy it.
it is located at the back:
[IMG]local://upfiles/1/5816645BF3AE454A8C1BDFE56C9A5F80.jpg[/IMG]
[IMG]local://upfiles/1/331689774FEF43709B2581454D7D7542.jpg[/IMG]
Old Nov 3, 2004 | 07:07 AM
Martin's Avatar
Many thanks Sleepwalker, that should save me a bit of cash! I just need to find the part now.
Old Nov 4, 2004 | 06:57 AM
Martin's Avatar
Sleepwalker (or anyone who can answer the question!)
I have managed to source a secondhand PSE pump, will this present any problems with coding when I fit it to my car?
Cheers
Martin
Old Nov 4, 2004 | 10:22 AM
if it comes from the same model as your car, no need for coding.
Old Nov 8, 2004 | 02:03 PM
Martin's Avatar
Default RE: SLK 230 PSE pump - part #
Still need some help here guys.....
I have sourced a secondhand PSE pump for my SLK230. It is from exactly the same model and year as my car but the part numbers are different.
The PSE pump on my car is part number 170 800 0548
The part number on the secondhand unit is 170 800 1248
I want to make sure they are the same part before I part with my hard earned cash, can anyone reassure me???
Thanks (again)
Martin
Old Nov 8, 2004 | 10:36 PM
better give me your VIN.
i cannot find 05 or 12 either.
Old Nov 9, 2004 | 03:26 AM
Martin's Avatar
Thanks for your help Sleepwalker.
VIN # is WDB1704472F146551
Cheers
Martin
Old Nov 9, 2004 | 06:26 AM
the right latest part number is: A170 800 08 48.
you can also use the older number 02, 03, 04, 06.
cheers.
Old Apr 21, 2005 | 07:22 AM
gary350's Avatar
Owners of later models SLK 2003/4 are saying that the pump now is fitted upside down so the water can drain out of the 3 holes in the cover, gets round the water coming down the cables.
gary
