Where to find ???
Old 04-18-2014, 07:47 PM
Mercedes Tin Man's Avatar
Default Where to find ???
I posted this on the amg forum also, but I think they will be the same as the AMG part is not part of the problem.
I am told that the ESP MODULE on my wifes 06 sl55 is bad....
I have a source for the part but he needs the part number to match it
OK am I looking for something under the hood or in the trunk.
Some one jump in and tell me.
THANKS, STEVE
Old 04-19-2014, 05:57 PM
chassis221's Avatar
THANKS, STEVE
should be behind the passenger side headlight on the ABS brake unit. it has a bunch of hydraulic lines going to it. The esp control unit is screwed onto that. I just replaced one this week on a S63 AMG 2008. The part numbers on the front of it you should be able to see it.
Old 04-19-2014, 08:03 PM
Chassis 221, Thank you, I appreciate the info
Old 04-25-2014, 03:46 PM
chassis221's Avatar
That esp module will need to be programmed. It will not work without it.
Old 04-25-2014, 10:38 PM
brookings's Avatar
Do they lose programming if unplugged? would a used one need re-programming?
Old 04-26-2014, 07:17 AM
chassis221's Avatar
Unplugging is ok. I dont think a used one will work. I would imagine if its the same chassis and same traction control system it mightl work, but I honestly dont know. When you install a new one it goes through a series of tests called initial startup. It checks and calibrates the abs valves..
md3845
02-20-2004 08:26 PM
captkickass
01-25-2004 02:20 AM
rt30000
12-16-2003 09:46 PM
groove
11-14-2003 11:04 PM
makaveli
11-07-2003 04:28 PM
Quick Reply: Where to find ???
