Seat Belt Trim Pad
there are three screws that hold it in place. chances are the plastic tabs are broke from age. may need to find a new assembly. used may be problematic as well due to age. might be able to jury-rig some metal tabs using a good glue or re-inforce the broken pieces with a thin metal like from a can lid. need to remove cushions and side panel for a better look. mine has two fairly large Phillips screws under the front on each side to remove bottom cushion and then tip seat forward, there are two torx screws at the bottom of the back plate to remove the back cushion.
PortalanzaMD
05-17-2010 01:54 PM
teo977
04-14-2004 10:00 PM
