Help removing key switch Please
I have a 300SL with a bad contact in the key switch (to the starter solenoid).
The NSS checks OK and the car will start with a screwdriver at the solenoid.
I'm looking for some advise on the removal and replacement of the key switch. I assume that it comes out from behind the dash and I'm wondering if I'm going to need specialized tools for the job. I couldn't find anything helpful on line and I'm wondering if there are any helpful tips I might want to know before I get started with this. It looks like it's not going to be a walk in the park.
Any comments will be appreciated.
Well, my 96 tried that dirty little trick, start sometimes not crank other times...
I wired a "push button" under the dash where I could easily reach it and just "push the button" with the key in the "ON/Run" position... easy to wire up and no one will be able to start your car with out knowing about it...
Try it! Cheap and easy!
The "Old Timer"
The "Old Timer"
Find a power source at the fuse box under the hood to provide "fused" power to your push button and run the other side to the solenoid... you'll need to drill a small hole up under the brake pedal or run it through a grommet if you can find one down there...
Put a small piece of 1/4" rubber hose on the wires where they go through the firewall...
Works everytime...
Works everytime...
MARIODRIVE
11-23-2008 05:39 PM
aenglish
03-31-2008 03:11 PM
