S500 rough idle
S500 rough idle
Hi, I have a 96 S500 with a rough idle problem. Regardless of engine temp the vibration from idle is very annoying. Engine mounts are good and it drives fine. Any ideas what would cure this? Is it possible for the O2 sensors to cause this idle problem? Thanks
RE: S500 rough idle
I had rough idle on my 1997 S420. It happened shortly after I changed the spark plugs. It felt like it was firing on only 6 or 7 cylinders. Took it to an Inde and diagnosed a coil pack problem. I probably nicked it up or something when I was changing the plugs, or it was just due for replacement.
They are about $90-$110 a piece, plus a little labor. I only had two replace, so not too bad. I might do it myself again if it happens.
Trick is knowing which cylinder is not firing, and that's where the error codes come in...
Let me know if you buy a code reader, I'd be interested in knowing what they cost and how effective they are.
Cheers.
Cheers.
WaBenzer
08-26-2008 05:41 PM
