2002 S500 Air Suspension cracked
Old 08-29-2007, 08:03 PM
gixxer's Avatar
Default 2002 S500 Air Suspension cracked
is there any way, to get itreplaced cheaper then 3000$? maybe get a used ones, or something... or maybe even get it fixed instead of replacing it. and what is the actual name for them, is it air suspension cylinders? thanks
Old 08-29-2007, 09:07 PM
chassis221's Avatar
Default RE: 2002 S500 Air Suspension cracked
yes you can buy a repair kit at the dealership and it can be fixed, for about $600 at the dealership, labor time where Im at is 3 hours total. the parts are i think $90- $130 per side. i repair them frequently. Do not replace the struts!! We call them strut tower caps, parts department will know what you mean.
Old 08-29-2007, 09:15 PM
right on chasis221- fix the problem- not replace unneeded parts.
Old 08-29-2007, 09:34 PM
gixxer's Avatar
thanks alot guys, i guess local german car specialists tried to bend me over and make some money on me
Old 09-06-2007, 02:50 PM
gixxer's Avatar
do you guys think I can fix it myself with that kit that they sell? I know some stuff about cars...
Old 09-06-2007, 05:47 PM
chassis221's Avatar
probably not because you need to press down the old seal and remove it from the top of the strut. and you need to chip away all the black stuff that is on top of the seal( the stuff that has the cracks in them). then you will need to pump up the system and clear codes. there is a tool that screwson to the 3 strut mounting screws on top then it will press down the old seal so you can remove the C clip that holds it in. I wouldnt do it myself without proper tools,you could run into more trouble.
Old 09-06-2007, 07:58 PM
gixxer's Avatar
good explanation, thanks again
Old 09-06-2007, 08:03 PM
chassis221's Avatar
not sure where your from but I will do it for $200.
  #9
Old 09-06-2007, 10:45 PM
gixxer's Avatar
Seattle, WA
  #10
Old 12-27-2007, 05:20 PM
gixxer's Avatar
Hey, I'm still trying to fix this problem, right now my back raised really high and my front sits really low, its really bothering me, I cant even drive it, and I asked some german shops and they dont know anything about the repair kit, they just want me to replace the whole thing for 3000$, I'm screwed up right now, Im still paying for the car and its just sits in the drive way
Quick Reply: 2002 S500 Air Suspension cracked
