oil filter location-removal 1997 E420(V8)
Old 05-23-2004, 07:57 AM
hirsel18's Avatar
Default oil filter location-removal 1997 E420(V8)
I have a 1997 E420.
Is the oil filter removed from above or below? Does one need special tool the dealer sells for $65?
Thanks,
Gerry
Old 05-26-2004, 11:55 AM
tom's Avatar
tom
tom is offline
Default RE: oil filter location-removal 1997 E420(V8)
hi , I have the same car . as you face engine it is on the left side next to air cleaner. you need to take off
air cleaner cover and then the housing . i believe it is 1 bolt and then they have a pop in and out ball joint.
it is really easy to do. you can't see oil filter housing until you take cleaner off. once off you can use any adjustable wrench but a socket would be prefered. the filter is housed in a cylinder . i get my replacement filters from performance auto on line as they are half the dealer price. i believe the last time they were $7-$8 dollars.
Old 05-26-2004, 09:57 PM
hirsel18's Avatar
Thanks Tom,
I now know where the filter is located.
It looks like a 13 mm socket will fit on top of bolt that goes into the cannister.
dealer was telling me to get a special tool.
Looks like set up of my 1986 BMW 535.
I removed the air filter paper element but the housing that it fits into stays put. Do you just yank it up and out or is there a nut/bolt that needs to be undone first?
Thanks,
Gerry
Old 05-27-2004, 11:29 AM
tom's Avatar
tom
tom is offline
Gerry, I had to go look myself because I forgot. Just pull it up. When you replace it back in you will have to align the rubber back up. The whole process is alot easier than one would think, isn't it?
I had a 93 e , but the filter was in the upper back right corner. I new what to look for on this one.
Hope it worked out for you .
Tom
mehdii20
07-13-2014 11:39 AM
ericnering
12-22-2004 11:29 AM
ncipps
12-06-2004 12:17 AM
omega
06-03-2004 10:51 AM
omega
06-03-2004 10:42 AM
Quick Reply: oil filter location-removal 1997 E420(V8)
