Fuel Pump Problems 190E
Old Sep 3, 2007 | 12:01 PM
jgruber's Avatar
Default Fuel Pump Problems 190E
My 88 190E with a formerly loud whiny fuel pump is suddenly quiet and will not start. I suspected fuel pump had quit but when I checked voltage across both terminals at the fuel pump Ishow no current. Again I checked voltage across both terminals and not voltage to ground but I made the assumption that the wiring going to the pump was + and- and that the pump was not grounded to the chassis. Someone correct me on this if I'm wrong please.
Anyway, is there somesort of fuse / relay for the fuel pump? I checked every fuse in the fuse box and all are passing current properly. Connections aren't green and corroded etc. There are 3 realys in and around the fuse box but nothing in the Owners Manual indicates what these relays power.
I'm hoping problem is a faulty relay or fuse instead of an expensive fuel pump as this car is destined to go up for sale very, very soon.
Jim Gruber
Dayton, OH
notbeowulf
Aug 19, 2009 05:53 PM
jgruber
Sep 3, 2007 11:55 AM
jgruber
Aug 13, 2006 09:44 PM
Buzby
Nov 23, 2005 12:19 PM
spcmartin
Aug 29, 2003 06:59 PM
