Blue vs. Yellow Coolant
Old 09-08-2005, 09:23 PM
sleepwalker's Avatar
Default RE: Blue vs. Yellow Coolant
9,0 liters for 104 engine. (uberwgn)
11.0 liters for 119 engine (GOMES). also every 3 years.
yellow or blue... it doesn't matter.
the blue color got a dye which turns into crystalline powder when in contact with open air and dried. this is only to aide on finding the leak.
  #12
Old 09-08-2005, 09:47 PM
uberwgn's Avatar
sleepwalker, you're the best. Thanks for your help!!
  #13
Old 09-09-2005, 01:25 PM
GOMES's Avatar
Thanks. Carry on with the good job well done (~.~)
  #14
Old 09-14-2005, 12:31 PM
uberwgn's Avatar
OK, I probably should not ask this question but I will:
[flamesuit] Should I use tap water* or should I use distilled water to blend with my fresh blue coolant?[/flamesuit]
Thanks.
*we're on city water, it's good quality and is not severely loaded with minerals.
  #15
Old 09-14-2005, 02:06 PM
Tap water is fine in the radiator. Use distilled water in your battery, if it's not maintenance-free.
  #16
Old 09-14-2005, 05:19 PM
uberwgn's Avatar
OK, thanks, Lugnut.
Just got back from the dealer and he says there's no blue coolant, it's factory fill only. So, I just grabbed a couple of gallons of the yellow and headed out the door.
audihenry
11-13-2014 06:02 PM
Mercedesparts
06-26-2014 10:33 PM
JERSEYSURFER
10-02-2008 01:03 PM
efylon
11-01-2007 09:43 AM
dlicheri
07-16-2005 11:39 PM
Quick Reply: Blue vs. Yellow Coolant
