Changing the serpentine belt 2001 E320?
Old Jul 22, 2005 | 12:29 PM
vifa84's Avatar
Default Changing the serpentine belt 2001 E320?
I am doing some maintenance on my 2001 e320. Finally got the oil change down with some help from this forum. I want to change the serpentine belt but don't see the usual 3/8" square drive hole to move the tensioner. What looks like the tensioner is on the drivers side above the air compressor with a nut next to the pully and a torx bolt through it. How do I remove tension?
thanks,
vifa
Old Jul 24, 2005 | 01:49 AM
Mark Cummins's Avatar
Default RE: Changing the serpentine belt 2001 E320?
Use a long breaker bar with the TORX socket to release the tension on the belt... hold it and then replace the new mono belt...then release the tension ..very easy!
Old Jul 25, 2005 | 05:10 PM
fastboy143's Avatar
Is it similar on an E-420?
Old Jun 27, 2010 | 01:48 PM
coolmilk's Avatar
how to remove the tensioner on 1998 mercede E320
Old Jun 27, 2010 | 01:53 PM
coolmilk's Avatar
please advice
Old Nov 15, 2010 | 01:20 AM
lukelelu's Avatar
Default No need to remove the Tensioner, just pull back a little.
When you are changing the serpentine belt, normally there is no need to remove the Tensioner, just pull back a little using a long breaker bar with the correct Torx sucket (normally I go to AutoZone to rent these tools (free of Charge, they will take your credit card number down just in case you don't return the tools). Anyway, just pull back on the tensioner a little - (it is spring loaded), pull back enough to slide your belt on, once the belt is on release the tensioner and DONE!
Old Dec 12, 2010 | 01:54 PM
JimPurdy's Avatar
Thank you, I kept looking at the tensioner and trying to figure out how to loosen the tension. I have both torx and e-torx sockets so I was able to remove the belt to spin the idler pulley. The pulley indeed does need to be replaced since it makes noise when I spin it. Tomorrow I will buy a new pulley and replace the bad one.
Old Jun 25, 2011 | 04:19 PM
gjamesfuss's Avatar
I also can not figure out how to loosen the belt. What pulley is it.
trivett
Nov 7, 2010 03:17 PM
PortalanzaMD
May 17, 2010 01:54 PM
fraguada1
Mar 14, 2008 10:16 AM
aquariuspg
Dec 31, 2007 01:27 PM
Paul
Dec 30, 2003 05:59 PM
