Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
CL500 (2000) Misfire
Old 02-12-2007, 11:23 AM
kelticcare's Avatar
Default CL500 (2000) Misfire
Having trouble with misfire that dealer has not been able to solve.
Codes say misfire cylinder 1, and MAF sensor fault. Dealer has:
Changed MAF sensor
Swapped plugs, coils etc, still says cylinder 1
Swapped fuel injectors, ditto
Compression test OK
Initially misfired when accelerating hard, but now much worse.
I have car back again from the garage, with maybe its the ECU?
Anyone any ideas
Thanks[/align]
Old 07-01-2007, 11:18 PM
kcattorney's Avatar
Default RE: CL500 (2000) Misfire
Was wondering if you got it fixed and what was the problem. I've got a 2000 E55 with a similar problem (throwsa cylinder 3 misfire but only under full throttle acceleration going from 2nd to 3rd gear). Drives fine other than that one situation. My Mercedes mechanic is stumped after going through the normal troubleshooting.
crosbyaa85
04-10-2012 06:30 PM
Slug-Gunner
03-24-2011 09:21 PM
Slug-Gunner
10-08-2009 01:37 PM
mtruong131
12-16-2008 12:54 PM
simomoco
06-07-2006 11:37 PM
Quick Reply: CL500 (2000) Misfire
