No air from center dash vent. Slow trunk latch. Vacuum related problem?
Old 08-02-2007, 12:02 PM
RProsser's Avatar
Default No air from center dash vent. Slow trunk latch. Vacuum related problem?
1997 C280, well maintained, 110K mi.
The center dash vent no longer flows air -- air only flows from the defrost and side vents. Also, possibly related, the rear headrests wouldn't retract when the button was pressed.
Research shows both symptoms can be a vacuum problem. I've read that the air vent problem *might* be caused by a faulty "vacuum pod." But how to I access it? I cannot find any how-to data.
Inspecting under the hood, I found a gray vacuum line that was off. It was near the oil filter, under the intake manifold (thanks no doubt to some knuckle-dragger at Jiffy Lube).
Time for a test: I started the engine, and hit the button again. Down the headrests went! Next, the air-con controls: I cycled through the air-direct button and, for the first time in many months, I was greeted by a blast of cold air from the center vent!
However, after a few minutes, and more cycling tests, the air stopped coming out of the center vent. As far as I could tell, everything else still worked (including the head rests). Aw, @#%$!
I tried driving it around the block, going from light- to full-throttle, with speeds up to 60 MPH. Still no center air.
I guess it's a combination of problems. Do these clues ring a bell with anyone? Still sound like a bad vacuum pod inside the dashboard?
Any help would save me hours and hours of troubleshooting.
Thanks in advance.
jcp89300e
12-28-2011 07:25 PM
schumicat
12-08-2010 09:32 AM
RProsser
01-04-2008 10:28 AM
mirage6976
02-09-2006 01:55 AM
Dehaven
04-22-2004 02:02 AM
Quick Reply: No air from center dash vent. Slow trunk latch. Vacuum related problem?
