EGR valve replacement
Old 10-22-2007, 03:27 PM
Connie's Avatar
Default EGR valve replacement
Could someone be kind enough to provide detailed instructions on replacing an EGR valve on a 2002 C240?
Old 10-22-2007, 07:21 PM
mbgt's Avatar
Default RE: EGR valve replacement
its not that very simple it takes about 1 hour you have to remove the the top engine cover, then on the right side of the engine you will find the egr valve, you need to remove the 2 screws that hold the egr valve but sometimes depending on corotion is hard to remove the hose that goes from the engine to the egr valve but puting it back is more simple
drumsastro
06-17-2015 02:59 PM
eaglehome
09-25-2013 01:59 PM
te2173
04-21-2012 10:01 PM
te2173
06-25-2010 08:53 AM
NMB
08-21-2004 09:12 AM
Quick Reply: EGR valve replacement
