'02 c230k 6 speed not going into reverse
Old 09-25-2005, 11:06 AM
kazooguy's Avatar
Default '02 c230k 6 speed not going into reverse
Please help! The only way I can get the tranny into reverse, is to do so while the car is rolling either forwards or backwards, with the clutch in. All forward gears work fine.
Thankyou in advance for any replies.
Old 09-26-2005, 12:53 AM
Default RE: '02 c230k 6 speed not going into reverse
Have you tried checking the transmission fluid. I had a similar problem with a brand new c230 recently. The car was shipped 2 quarts low on transmission fluid. The car would drive fine except on a certain road. The fluid would be unlevel at this time and cause the car from not shifting properly.
Old 09-27-2005, 08:20 AM
sv4's Avatar
sv4
sv4 is offline
Keep the clutch in, then shift to 1st before shifting to reverse.
Old 09-28-2005, 10:30 PM
might need your clutch cable adjusted as well
Kirk Dockum
03-28-2012 09:15 AM
Daviddents
05-17-2010 12:30 AM
ddwong
11-02-2006 10:19 AM
winstonsmith6076
09-12-2006 03:33 AM
rscott77x
07-16-2006 08:19 PM
Quick Reply: '02 c230k 6 speed not going into reverse
