Fuel Distributor
Old 11-07-2016, 11:52 AM
Mark Davisson's Avatar
Default Fuel Distributor
I just picked up (from my son-in-law) a 1988 300E that had not been run for the past 10 years. Drained the tank, replaced the screen, replaced the fuel filter. With the fuel pump running and the air flow sensor plate deflected as far as it will deflect, I'm still getting no gas into the injector lines. I do have pressure at the inlet and outlet of the fuel distributor, though I haven't measured it yet to see if it is up to spec.
Is it possible the gas that sat in the fuel distributor for 10 years (and it was nasty) rotted the diaphragm and that this is causing no output into the injector lines?
Any guidance you can provide will be appreciated!
grendal10
06-01-2007 07:10 PM
tuk27
03-19-2007 10:01 PM
cmscott16
02-17-2007 06:53 PM
drolyat
04-25-2006 09:03 PM
1990300SELMAN
04-14-2005 10:59 PM
Quick Reply: Fuel Distributor
